Aftermarket sway bar?
hobosapien
So apparently my sway bar is rubbing on the the front struts. I have a 3" lift in the back, and 2.5" in the front (Toytec Boss). Are there any aftermarket sway bars that can be installed? It's making a really high pitched squeaking noise anytime I hit a bump or roll over something.
Icon makes a sway bar relocation "kit," just a couple of a spacers machined to move the sway bar forward a bit. worked really nicely for me. works with the original sway, or im assuming any aftermarket as well if you still were looking to go that route
Thanks! This is the route I'm going.
The relocation bracket that came with my Fox coilovers was bigger drop and offset than the one I had gotten off ebay earlier (but worked for my 5100s/885s) so you should be fine with any.
AndiGarage
