Ahhh antifreeze!!!
t4r4u2nv
Today i got in my 4runner and drove about 5 mile and parked and went inside when i got back out about 10 mins later i had a huge puddle of coolant underneath her so i popped the hood to see if i could find where it was coming from but had no luck. as far as i can tell its coming from the area im pointing at (behind the plastic cover) it appears to have sprayed up because the coolant is on the underside of the hood as well all over the top of the moter (mostly driverside) can anyone please assist me in finding out what is going on? checked my coolant reserve and it was completely empty drove back home and temp gauge was normal everything drove okay as well??? idk what it is!!! t4r.jpg
well thats your timing cover so could be the water pump but i dont know for sure but i would check that as well as the hoses
You pointing to the plastic over all the wire's? There are coolant line's going to the t body and manifold, you might want to check those.
Zett
