Airlift 1000 filler placement?
Ok, getting ready to lift my rig and going to add airlift 1000 bags on the rear, searched through 10 pages of airlift threads and haven't found any pics of where you guys are putting in inlet nozzles to fill the things???? I thought I saw a pic a while ago but now I can't find it? I would like to have the ability to add air on both sides without having to raise the rear hatch. Reason being I would have my motorcycle hauler on there with two bikes.
And yes, I will post pics when I'm done, I have done a ton of mods to this thing in about two weeks thanks to reading this forum!!!!!:reddance:
I don't have a picture but we made a little plate and attached it behind the bumper mounted to the hitch. The valve is facing slightly down and is easy to access, but tucked up and protected.
I put this system on my vehcile about 6 months ago. I installed the filler next to the trailer light hook up. Drilled a small hole through the bracket. There is enough clearence off to the side of the plug. I only ran one line for both sides. But you could easily put another fill down there.
Another thing. The install says you can do it with out removing the springs. Sure I suppose this is a possibility its much easier to juse take the springs out. Took me about 2 hrs. I also mounted the bags upside down (hose connection at the top) this provided me with a easy route for the tubes through the body rails (to avoid having to contend with fastening the tubes to the axel) to the back, and around the spare tire. So far so good. :)
