AJT Radio Knobs here!
Senior Member
AJT Radio Knobs Finally in, got my pre-order today:
In product description it says "no tools install". I guess those just press fitted and just pull out. I'll find out when I receive new ones. These look awesome compared to blah OEM. I was waiting for Climate control matching Radio dial for some time and glad Mike finally came trough.
Do you know if the radio knobs are like the climate knobs in that they pull straight off.
Yes, they just pull off. The climate control knobs require you to swap the light lens from the old knob to the new one, and you have to install some decorative Allen screw, otherwise a very easy job.
Yup - just got mine and installed. My radio knobs were on there pretty firmly, so it took a good tug to get them off. The new AJT knobs don't seem to fit as snugly as the factory, so time will tell if that proves to be an issue or not. Regardless they look great and match the climate knobs.
Blocked LED ring light?
Hello,
I'm wondering if the radio knobs will now block the LED blue ring that is around the knobs. Thanks for the help!
These do not block anything. Rings stay visible as with OEM. gsla72, e-mail AJT and they will send you revised version free that fits same as factory - tight. Their first batch was little out of spec but now it's fixed.
Thanks for the heads up! Emailed AJT and they shipped me out a replacement set right away. New pair is on and fits snug as can be.
