Alarm light wiring help
F4injected
As you can see, the alarm light wire has been disconnected and I have NO idea where it plugs back into. I took a look around but couldn't find anyplace where it might be plugged in. Anyone have any ideas?
That appears to be aftermarket, if you don't see something for it to be plugged into then it may have been removed. Are you the original owner?
From your picture it appears your truck is like mine, V6 2wd Sport. Where that light is wired it would be a blank from the factory, blank, blank, Trac Off, blank.
hmm I think I have
Red led, blank, Auto LSD, blank
You don't have Auto LSD? I don't have Trac off...
I have a 2007 v6 2wd sport
hmm I think I have
Mine is an 2004. The Auto LSD is pretty much the same as Trac Off, just Toyota's new terminology for doing basically the same function. Back to your LED, I feel it is definitely after market as I have had many Toyota's over the years and have never seen a factory LED like that.
I wonder if the previous owner just set it up for looks or something.
Jhunt
