Alignment question
Rushingman
I tried search for this, and couldn't exactly find the answer I wanted.
My friend has a Silverado with 20x12s and 35s
My 4Runner has 17x8 and 35s.
I am wanting to test his wheels and tires on my 4Runner to see if they will work and what might need to be trimmed for them to work.
Are either one of us going to need an alignment after we put out ORIGINAL wheels and tires back on?
Even if the bolt pattern is the same, one thing you may run into is hub-centric vs lug centric. Hub-centric wheels center the wheel based on the hub, and the lug nuts just hold it on. Lug-centric wheels use the tapered lug nuts to center the wheel on the axle. The 4runner is hub-centric - I don't know about the Silverado. You may have trouble getting the Chevy wheel to fit properly and center up on the 4runner, and vice versa. Could wind up with some off-centered and or wobbly operation. Be careful when you try it out.
But trey99ek is correct - won't affect the alignment at all.
I don't know if this helps. Butttt
They are both the same bolt pattern
My wheels are stealth custom series sr8
Silverado wheels are fuel Mavericks
mek
