Alignment
calcrc
Hello, I brought my truck for a check up since I noticed it was pulling on the left side when driving on the highway.
They said they need to change the bushings of the stability bar because it was loose.
Also the truck was half an inch higher on the left side, they fixed that also.
On the paper it said calibrate the kdss system and steering angle.
Here is a pick of the alignment once all was done.
I see the numbers but I don't really know what to make of it. Other that it seems to me the truck will still pull on the left side from the numbers on the picture.
I haven't driven on the highway yet but I will make sure everything is alright you're comments are always appreciated. :)
Hold on, let me get my French to English dictionary and get back to you :keyboard:
Did you ask the alignment tech if he has already maxed out the caster adjustment? Have you ever hit anything like a curb or big pot hole?
Don't quote me on this because I might have it backwards...but I think in a situation where you have cross caster, it will pull towards the least positive side (in your case the right); so...maybe he did that on purpose to counter the pulling?
I'd give it a careful drive and see what you think before you worry too much.
Well Yes Montreal' roads are bad, like very bad. So I might have hit something somewhere sometime since I got the truck. Ok I will see how it goes this week-end going back and forth to work. Thank you.
ghengiskhan
