All New Baja Designs LP6s!
The new LP6 from Baja Designs LED Lighting is ready for pre-order at Battle Born Offroad!
A design that was inspired by Baja Designs’ legendary 8" La Paz HID; The LP6 features modern styling and performance, with some of the most advanced LED technologies available today.
The LP6 (PRO) utilizes 6 forward projecting LEDS to produce 8,600 Lumens at 90 watts, and 4 LEDs for Integrated Peripheral Technology (IPT) which produce 1,700 lumens at 15 watts per side. The IPT provides an incredible 200° spread of usable light.
The housing was designed to provide exceptional heat dispersion by using Direct Ducted Cooling, which allows air to travel from the front of the housing to the rear. With a day-time running light, low, and high power mode, the LP6 will fulfill all your lighting needs.
Available in a standard model that is perfect for a wide range of off-road use, as well as a Racer Edition configuration that is designed for the demands of high speed driving. The Racer Edition has similar power draw, but produces a much tighter pattern, providing higher visibility at greater distances. Both models feature uService technology, which allows customers to change the lens pattern and color depending on driving conditions, or simply when they want to refresh the lens.
LP6 Pro
Available in Driving/Combo or Spot
White or Amber
Starting MSRP $474.95
Click here to PM us - lets talk lights!
Contact for special T4R member pricing
BATTLE BORN OFFROAD
FACEBOOK | INSTAGRAM | EMAIL​
Prictio
