All window auto down
hockeyman
It's likely too specific of a topic to try to search so I am just going to ask it here. Has anyone ever bridged the function of downing all 5 windows with the key fob button for the rear window. One of my favorite little pleasures with this truck is being able to walk up on it from several feet away and lower the rear window. It's gets pretty hot in SoCal and I would like to be able to use the key fob button to lower all of the windows in the truck as I walk up. This helps relieve some of the heat in the truck before I have to get in.
Also, I had once heard that is it bad for the AC components to shut off your car (ignition) while the AC is still running. Typically I will shut off the AC system prior to shutting down the engine. I was debating getting an alarm system that can start the truck which would also turn on the AC/heat, but of course, you have to leave the AC on in order for this to be of any value.
Thoughts?
seltzernator
