Almost flipped my 4runner, need help
parks71
I installed an OME 3 inch lift about a month ago, then I put on 275/70/17 tires. I asked the shop to align the truck but they said they couldnt due to a bad tie rod. I replaced the tie rod about a week after and took it back again.
This time they said they couldnt do it because the couldnt get the other tie rod loose to adjust or or the bolts to adjust the camber etc. So I go buy all the parts to replace this stuff. In the mean while, I have driven around 700-900 miles on the truck lifted with zero issues. I cant even tell it's out of alignment but I know it is due to the lift.
So I go to replace the other tie rod and the bolts but I was able to break the bolts free with a breaker bar and impact gun. Shocking the the shop couldnt do it, I was pretty disappointed because I got them all free in 15 mins.
Anyway, I just took it back to the shop AGAIN and they aligned it but said it's not perfect because of one of the camber bolts was not working right but it's only 2degrees out and it shouldnt matter. The toe is perfect.
So I just picked it up, was driving it home which is about 6 miles away. The truck is driving great, I am going about 70mph and about to exit and all of a sudden the steering wheel jerks right hard for no reason. So hard, I thought I must have blown a tire. It scared the CRAP out of me because the damn thing swayed so hard.
I exit and get out and the tire is fine. Now I am scared to death to drive it. I drive it home at like 40 mph and no more issues. I turn back and forth, do circles in the neighborhood, I cant get anything to screw up. I looked under the truck for anything loose, nothing I could see, lug nuts tight and it appears the nuts on the caster bolts are tight and the tie rods. Any idea what could cause something like this? I am obviously going to take it back to the shop but I have a feeling they are going to say they cant find anything wrong.
not to break the mood or anything.. But maybe you should drive back on that exit ramp and look for a pot hole of some type. Just an idea.
Edit: 034x4 beat me to it!
FYI, 2 degrees is a LOT. it should pull like a mother to the opposite side.
and it will wear the tires FAST that far out.
on top of that other issue.
i wouldnt drive it anymore, except to get it somewhere to be looked at/fixed.
yeah dude something doesnt sound right if the shop you went to couldnt undo the bolts yet you could and also that they kept saying something else was wrong. I would find a new shop and get them to look at it and get it aligned properly and get them to check out everything to make sure you dont get in a wreck, good luck.
Was wondering if something was hung up and let go? Maybe there was a bind in something or something broke lose? Other than that maybe a combination with the road and your 4Runner? I have worked with drivers for years and seen lots of weird crazy stuff, so you never know. Maybe get your runner in the air and look it over very closly turn the wheel put pressure on some of the parts check all the bolts and links.
AND FIND A NEW SHOP!!!
Just had another idea what kind of lift? Check your springs and mounts check the shock mounts. Seen people put spring seats upside down. If you have 5100 Bilstein could have a snap ring that could of been put on incorrectly? make sure your tie rod is connected properly on both side and the mounts are good. Look at the rear suspension as well.
Just trying to through out some ideas. Very curious let us know how things go.
maybe they weren't using the alignment adjusters correctly in the first place. then after you brought it back in they tried to align it and didn't tighten things back up correctly.
i had a similar issue with Firestone after getting new tires. they said they couldn't break the adjusters free. they said to bring it somewhere to break them free then bring it back for the alignment. my mechanic friend broke them free no problem and thought they were not loosening the correct "side" of the bolts. i can't remember all the details, but we got it resolved in the end.
