Alternate control arm bushings
RS Dude
Member
The Toyota OEM bushings are outrageously expensive. I was considering aftermarket bushings such as Moog. Anyone have experience with aftermarket bushings either good or bad?:jump:
You also have an option of buying used control arms from a junkyard with a truck with less mileage. I did this.
The front control arm bushings are a pain in the arse to take out/install of the a-arm, so make sure you either got a good press setup, or take it to your favorrite shop for them to do.
I am sure the Moog's are fine, just stay away from the polyurethane aftermarkets, as I've heard they are problematic.
