Alternator Electrical Connector
calrider
I'm replacing my alternator for the first time and have all of the bolts removed. Everything is free except for this damn electrical connector. It won't budge...at all. Sprayed some wd40 down in there to try to loosen things but so far no luck. Does anyone have any suggestions?
Press the connector into the alternator, then press the tab on the plastic connector and now it is good to pull
As nissanh says, push tab.... however, mine was really stiff too, I found the plastic tab was hardened... I ended using some pliers to gently press on the tab, then pried on the connector, with a small screw driver, between the connector and the body--- side to side.
