Billynath1988
Senior Member
Ill try to keep this brief but informative, since there is a lot of threads and information out there on this topic already. None that I found particularly helpful.
2005 V8 SE with 145k
I recently did a CV boot replacement on the drivers side. For those that dont know, it simply involves taking the cv axles out of the hub and then the diff.. After buttoning it all back up I got the dreaded triple lights plus the ABS light. Everything was completely fine before and then this. I know I was gentle and careful with the wire but its old and original.
visual inspection of the sensor wire and plugs showed no sign of stress but age is a factor and they might of been somewhat brittle. I drove the truck around, unplugged and re plugged the sensor at both ends and reset with the battery with no change.
Multiple threads here would have me believe I must of over stressed the sensor harness during cv replacement and broke some wires internally. I assumed this was a safe bet however did not check for continuity in the harness. I ordered a new OEM harness off amazon for 25 bucks.
Installed harness and no change. I removed the actual sensor and found the tip had been cleanly sheered off. Angry but confident I found the issue I ordered a new sensor.
Installed new sensor onto the new harness and.. Still no change.
I went back to where I started and pulled the hub off the axle. I noticed there was debris that had fallen into the sensor track near the bearing including melted sensor parts and also this took out the second sensor.
I cleaned it all out carefully. and ordered yet another sensor. I assume this will fix it but who knows. hopefully this thread gives people another place too look when chasing these problems.
Solved: replaced hub assembly, debris from ruined sensor destroyed magnetic sensor strip in hub.
