Here is the pick of the CAT.. Not much to look at, but you can also see in the pick that I started on the frame, sanding, rust converting and spraying with a flat black. I will work on it thru the winter as there is A LOT of rust; more surface than anything, with a few bad areas like the rear axle housing.
I also pulled off the skid plates, degreased, wire wheeled, sprayed metal etching primer, then coated it with Por15 (I have a quart left over from the last Mustang I rebuilt)
