Angel Eye Mod- By LoneWolfOverland
MrSeth
Member
So. This is something I rolled out a few days ago, and it seems to be picking up some speed.
This is a step-by-step tutorial on how to complete the Angel Eye Mod.
Materials:
2x Standard 9006 Headlight Bulbs
2x Side Marker LED's
Drill
5/32" Bit
Dremel with either a sanding attachment or metal cutter attachment
Hot Glue Gun
Let's begin!
First, take out the bulb you wish to modify.
20180126_193445
(I had a few Sylvania's laying around)
Next, we are going to use to needle nose pliers to break the small spot welds holding the bulb to the housing. Be gentle, these will break off easily.
20180126_193550
It should look like this when finished. You can twist the light bulb in between your fingers to pull the leads out of the housing.
20180126_193815
Next, carefully extract the retainer from the housing. I say carefully because the metal can be sharp and any jerking motion could slice your fingers up.
20180126_193939
Next, we need to Dremel out the plastic retainers for the metal ring in order to make room for the cylindrical LED housing.
20180126_194248
You can use a barrel sanding attachment, but I had a metal saw wheel for plexi-glass cutting laying around that I used with success.
20180126_201001
Should look like this when you are finished.
20180126_201313
Note the two holes inside from the old leads- we will be drilling through these shortly.
I used a 5/32" bit to drill this out. It's a good size, because you can get the hot glue inside of the housing around the wires that exit the rear.
20180126_201549
20180126_201540
Next, grab your LED side marker. I ordered a bag of them from Amazon for cheap since I am replacing my Raptor Light mod lights.
20180126_201722
Remove the 3/4" grommet from the light.
20180126_201731
Next, feed the wires from your LED light through the previously drilled holes in the back of the housing.
20180126_201846
Next, we are going to push the LED into the 9006 housing. It can be considered an interference fit, and is a little tight. You shouldn't have to force the light. If you are having the force the light into the housing, dremel out a little more.
Here are my measurements taken.
20180126_202110
20180126_202135
The fit.
20180126_201953
20180126_202253
Next, we need to seal up the housing so we don't get moisture in our headlight housing. I use hot glue, but I'm sure you manly men can use JB Weld if you wanna.
20180126_202434
20180126_202702
And voilla! You have completed your mod. You can either wire them into your turn signals or running lights. Mine are wired into my raptor lights.
WOT
Thanks everyone! Safe wheeling :)
i think i like to keep my functioning high beams. only recommend this if you have retrofitted some bi xenon hid projectors. but still that wont light up for the flash to pass in the daytime.
Materials:
Drill
5/32" Bit
Hot Glue Gun
Let's begin!
20180126_193445
20180126_193550
20180126_193815
20180126_193939
20180126_194248
20180126_201001
20180126_201313
20180126_201549
20180126_201540
20180126_201722
20180126_201731
20180126_201846
20180126_202110
20180126_202135
The fit.
20180126_201953
20180126_202253
20180126_202434
20180126_202702
WOT
I suppose I should change the mod recommendation to "For Moderately Modified 4Runners"
Agreed. I mean, my flash to pass with about 65k lumen, people think its the second coming of Christ in their rearview mirror lol. And you are right, if you are running standard halogens, you may want to keep your brights- especially up here in the mountains.
I suppose the other two requirements would be
1. upgrade the standard headlights
2. have an alternative to your brights
H.Sikina
