Another disconnect battery thread..
genest1417
I have read the other threads about the disconnect battery issues. My issue is a bit different, I think. Battery was disconnected to work on a AC problem and my key fob does not work at all and my interior rear window dash switch does not work either. The window lock is not applied and the rear window will go down using the key. To normalize the window the manual tells you to use the switches which I can't. I am also trying to figure out how to get the key fob working again. I think this same thing happened a couple years ago but I am to old to remember what I did to fix it. A little help from the younger folks would be appreciated.
Jhunt
