BrianSD_42
I'm going to throw my .02 in here and say I HIGHLY doubt it's a head gasket. You're willing to just dive into doing the work without even properly diagnosis? Good luck!
OP, I have to agree with BlackCat914 here. Going just off what you mentioned so far you haven't done a proper diagnosis. We see other trucks with smoke that isn't the head.
Lets see:
Intermittent Smoke: Yes (was it during startup or consistent)
Codes: No
Runs ruff / misfire: No
Coolant in the CYL: No
Confirmed compression problem: No
Oil in radiator coolant: No
// I just saw your comment about experience. I don't doubt you can do it but it might not be the heads.
The parts you use, gaskets and such will be inferior to Toyota's gaskets and if the original gaskets aren't actually leaking then ...
It could be a cracked head but if it is a simple compression test at a local mechanic will tell you that for 30 mins labor.
Also if you are burning coolant than when you pull your plugs, one or more of the CYL should show coolant in it and possibly have no carbon because it was burned off. This can be done without removing the heads.
There is a good chance if you drive it around town you may see the above symptoms so it may be a good idea to do a bit more test driving. Put 100 miles on it and see what happens. Also try driving for 30 minutes and see if the smoke is there, perhaps it was just startup smoke.
:cheers:
