Another lift question...
S2krunner
Hello guys and gals,
I am about to pull the trigger on these shocks on ebay, however I want to be absolutely sure I am purchasing the correct shocks. The confusion is brought upon the seller specifically saying that it is NOT for the 3 gen 4runner.
The ad is as follows...
Bilstein 5100 SeriesFront Shocks
for 2000-2006 Toyota Tundra 2wd & 4wd
Ride Height Adjustable
Bilstein 5100 Series Ride Height Adjustable Front shocks only
for a 2000-2006 Toyota Tundra 2wd & 4wd Only
(Shocks Are Not Designed To Fit 1996-2002 Toyota 4-Runners.)
Pictures are for Illustration Only, actual shocks may differ.
Fronts Only!!
<!--[endif]-->
Bilstein Part #'s:
Front Bilstein Shock Part #: 24-188265
Thanks in advance...
These shocks are equal to the Bilstein old part #’s:
BE5-6929-H1
Fronts Only!!
<!--[endif]-->
Bilstein Part #'s:
BE5-6929-H1
Get something for a 4runner or Tacoma. A link to what you're looking at would be helpful as well.
Fronts Only!!
<!--[endif]-->
Bilstein Part #'s:
BE5-6929-H1
Is your 4Runner lifted? These shocks are for lifted 4runnners. They are the same one I used with my Tundra TRD coils.
And tons of people run Tundra 5100s so...
You can run Tundra 5100s on a stock height 4Runner, lifting it doesn't help you fit a larger shock since your bump stops are still stock height which ultimately limits shock length.
x2 on MStudt though, a link and not a description would help.
Those front 5100 struts, Bilstein part #24-188265 will work perfectly. Tons of folks here use them, including myself.
Exactly! That part number is what's used with Tundra coils (as well as other coil options) to lift the front of a 3rd Gen 4Runner. No link required since you have the Bilstein part #.
There's a metric crap ton of threads on this.
