Any 2019 TRD PRO Owners Running 285/70 R17 Tires?
matoolie
Curious if anyone is running this size tire on OEM wheels & OEM Fox suspension without wheel spacers. If so, rubbing issues? Had to move fender liner forward? Remove mud flaps?
You will have to do the fender liner mod for sure and possibly remove mudflaps depending on the amount of caster you can get dialed in. You can fit them with just those two mods, so you should be good with simple fixes. BFG's run smaller than other tire brands so they will be your best bet to not have to do anything drastic to make them fit.
Hope that helps!
Jhunt
