Any direct bolt-on replacement calipers for 4th gen?
Jed
Banned
Just wondering if anyone has found any non-OEM replacement calipers that are a direct bolt-on for our existing brake set-up. I don't want to buy an OEM caliper or a remanufactured unit from an auto parts store because those are generally just rebuilt from the OEM caliper castings.
I also don't want to spend the money for a complete high performance brake set-up from Brembo, for example. All I'm trying to do is find a regular caliper that will work without having to worry about the pistons seizing inside.
Ideas?
Well I'm not 100% sure but I believe the remanufactured ones are "fixed" during the process. You'll have to wait for someone who knows more about brakes but I'm pretty sure I read that somewhere.
Interesting.... do you have any idea at all what is done to fix them?
I thought there were a few guys on here who installed remans and they ended up seizing again. I could be wrong about that though...
No sir I couldn't tell you. You may be correct, I just thought I read that somewhere on here. I wish someone else would chime in that has dealt with this issue before...
leolediola
