Its come time to replace my original front axles and was wondering if there is a reason to upgrade to something other than OEM or just stick with OEM.
Nope. Amazon has ‘em for 415. If you want ‘em cheaper, buy a rebuilt OEM axle or DIY.
Just installed a CVJ axle. Have you considered them?
CVJ Axles - CV Axles & Steering Racks for all your needs
hmmm...i got a 100% new carquest sitting in a box wondering if i should return??? though i dont wheel
i was checking these out the other day. what is the advantage of CVJ over OEM?Second this. If you run any sort of non-stock suspension (or even if you're stock), I'd suggest CVJ Axles.
is there anywhere to buy OEM at a better price than the dealer. They quotes me $500+ per axle
Not sure how to tell if they’re OEM, someone else can answer that, but you can get a Toyota reboot kit for ~$50-60 just about anywhere.not even sure if mine are oem or where to get parts to rebuild?
apparently i have oem but definitely need more than boots. i think ill take my chances and just hold onto my oems just in case
ill consider rebuilding if someone knows where i can buy bearings, etc
those are OEM Toyota boots so you'll be good to go. did it come with the grease and clamps, et cetera?What makes you think you need bearings?? Is it making noise and having some sort of vibration?
I just ordered these cv boots off amazon and they seem really high quality.
https://www.amazon.com/gp/product/B0099AQNAI/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
