I have done the tranny fluid flush/replace on my Tacoma and wanted to also do it with my 4runner now, but the setup is of course very different seeing as how there is no dip stick or refill tube for the tranny.
my question is, how will I get the fluid back into the tranny as fast , or close to it, as it gets pumped out at the cooler hose?
my thinking is, the return line can be used for refilling, but having never tried it, I have no idea how easy is it to do this? I am assuming it will not suck the fluid in and that it is just going to be a slow time consuming gravity feed process and it wont flow fast enough to refill at the same rate its is being pumped out the cooler hose and I will have to do it much the way I did on my Tacoma.
with the tacoma, I had to disconnect the cooler line, start engine and let it pump out about 2 quarts, turn off engine, refill tranny with 2 quarts and repeat until fluid comes out clean.
has anyone done a tranny fluid flush and replace and how did it go for you? any helpful tips you can share?
PS - just wanted to add, I know there is a fluid level plug you remove on the pan to be sure the level isn't over full and that will be done after I am finished replacing all the fluid.
also I know they "say" it never needs replacing but at 160k miles I am replacing it just for extra insurance
