Anyone else think this is annoying?
Brian3676
Love my 4Runner, but it drives me crazy how every time I get into the truck the HVAC controls automatically default to air recirculation. I like to always bring in outside fresh air and every time I turn the truck off and get back in it always switchs back to recirculation automatically.
Anyone know a way around it, or how to make it stay on its last setting when it was shut off?
I've only had my runner for a couple of months and noticed this too...It is quite annoying!
it is irritating. but I think mine does the opposite, at least it used to. it resets to fresh air. in the mornings when its freezing cold, I don't want outside air coming in..
not sure what I have done, but the last few months, it has stayed on recirculate...
maybe it has to do with the weather/air temps?
it does have to do with air temps. if it is warmer outside that you have it set at in the info display, it will start in recirc. if it is cooler outside than you have it set at, it will bring outside air.
for example, if i have it set at "LO" in the info display and it is 95* out, it will start in recirc. if it was 30* out, it would start in outside air mode
or at least this is what i have been able to make sense of after owning it through a winter
That is correct, that is how it works;
That is not exactly correct, it depends on outside air temp, set temp, and set fan speed from what i can tell. I normally leave mine set at about 68 and fan speed 2 and when i get in after work and the display shows 88 for outside temp it will start on fresh where I left it, if I move it up to speed 3 it will kick over to recirc.
to be honest ive had my 'runner for 5 yrs and never noticed this..i just get in and set whatever settings i want
*it is interesting how far things have come to where these types of things that are aggravating to some.... its a testament to how good these vehicles are where these are the gripes people have with them
Some people appear to see this type of thing as a hardship.
C'mon people - push the button and move on.
It is simple, but annoying. In the winter you do NOT want recirculation because your windows will fog up. In the summer you want recirculation when the AC is on so it is more effective and efficient. I will watch mine more closely, but I don't think it exactly follows the guidelines as stated above.
The problem is that (and Toyota has put out a TSB for this) is that when you use the A/C, you obviously get a lot of moisture build up in the Evaporator area. When the car is off and its set to recirculate, you don't have outside air flowing through the unit to help dry it out and minimize the smell. You tend to get a wet, mildew odor when you turn the system on. Sure it'll go away once you start driving or turn on the A/C, but you'd be surprised how many people come into the dealership and complain about it.
I did notice the recir is always on now once the temps started getting hotter outside. This totally makes sense. I hate how I have to turn AC off after I hit "Auto" if I want to run in "economy mode" but at least we have option compared to other vehicles.
In the humid south Louisiana climate I'm in I leave the A/C and the recirculate always on, even when I want heat. That way the cabin air stays dry. I would love to live in a climate that is dry enough not to have to do that. Oh well.
If it's anything like Lexus, the dealer can change that for you. My GS 430 used to do that until my service adviser plugged a computer into the car and unchecked a box on the personal settings screen. I would think our runners are the same. Lexus called those settings "c best" I believe. I don't get to drive my runner so I'm not sure if it's on every time or not.
IIRC you can remedy this by turning off the "auto" feature. Then the HVAC should stay in whatever position it was when the vehicle was turned off.
I don't think this is right. I have never used the AUTO setting, and it would switch every morning. drives me crazy.
The system is what it is. Lexus HVACs do the same thing. It's been like this for YEARS. Temperature/humidity factor on how much heat/cold come in and whether or not the recirc door is opened or closed. Like CSX said, just push a button and forget about it. The HVAC system is smarter than you. Deal with it. (and I respectfully mean that)
If I'm going to push buttons I like it to be to turn on the functions I want, not to have to turn off functions my car thinks are best for me!
My old Gen 3's HVAC controls were manual, and I don't remember thinking one time in the 12 years I owned it that it would be nice if it controlled the recirc for me. 99% of the time I like fresh air, and the only time I ever like recirculate is when driving through smoke or dust.
seltzernator
