Anyone have OEM Audio Plus installed?
kaitlyn2004
I have a 2020 4runner, so the system came with an extra harness to attach behind the headunit. I got the speaker + amp system, no sub.
When I installed the speakers I noticed a definite improvement, but by chance the way I installed I ended up doing the amp days later.
Once I installed and hooked up the amp, I felt there was NO audible difference between speakers only and speakers+amp.
I've been dealing with OEM Audio Plus on my issue and they have been great, but I also wanted to put it out to the community as maybe others have noticed something or found a potential reason?
I've done tests as best as I can, having played the same song both with the amp connected and bypassing it (Which is annoying having to go back+forth changing the connections!)
I've tested it mostly with android auto, but have also tried with radio and sirius. I've tried low-ish volume at around 20-25, and higher-than-comfortable volumes at 40 - and I feel there is zero difference in the loudness or my perceived quality of sound between the two setups.
Anyone else have a similar setup? Done any testing? Noticed anything or found any potential issues?
I've also been wondering if this $2k USD upgrade is worth it or should I just mix n match my own components for half the price. The main selling feature I gather from buying the full OEM+ kit is that everything is literally plug n play so you're basically just tearing apart interior panels.
I had an issue with my amp so I ran just the door speakers off of my aftermarket headunit for a couple of weeks. It turns out they just needed to reflash the firmware for the amp and it worked fine. I still noticed a difference with the amp in place but I also have the single sub.
It's pretty good for not having to mess with finding components. Dual sub is even better. In the end you can do better on your own if you want to put the effort into it. I find that the sub is in the way of platform/drawer systems so in the future I may be removing it and going with a custom sub in the passenger side pocket.
I'd like to hear what the resolution is. Surely something is not right as I have read review after review about how much better the OEM speakers sound with the amp and DSP added to the mix. I'm planning to get one of their packages myself, so I'll be following this one. The only thing I can suggest is playing a high resolution format via USB for your sound testing.
I installed all my own speakers and I'm more than happy with it
How do you like your Halo9? With your speaker choice, did you have to cut and splice or were they P&P?
Very happy with my Halo9, the only thing I wish it has is wireless Android Auto, but for a bit older HU it's an awesome unit and works great.
All my speakers I wired Toyota plugs onto them and they were all plug and play
If you want improved sound the biggest difference I saw was adding sound deadening to the doors. This really made the speakers sound a lot better. Even the stock speakers hit harder. I do have the Orem audio+ with single sub and dual amp. It sounds great but you can get louder crisper sound out of a custom setup
Keep going round and round on this myself. I've almost pulled the trigger on the OEM+ speaker only upgrade a few times, but it seems to be backordered whenever I'm ready. I'm not sure I'm ready to give up any space in the rear for a subwoofer just yet.
The Tacotunes speakers seem like a possibility. Focal used to make a direct plug and play speaker, however it seems to be discontinued through Crutchfield. Anyone with direct experience on either setup?
I'm also confused on the rear door/hatch speaker setup. It seems like there are a lot of recommendations to try to find 2 ohm speakers to keep the factory impedance correct due to the rear door/hatch being wired in series. Unfortunately, most aftermarket speakers are 4 ohm units. Am I way over thinking this?
I did the speaker only package and would buy it again in a heartbeat.
vast improvement for me.
your mileage may vary.
I did OEM+ the speakers only, and dropped a lot of hush mat in the doors. Night and day difference.
*I was planning to do the Amp eventually but threads like this are scaring me off...
Well what's catching me up is I feel like I'm hearing what is virtually, if not literally, no difference. But that also just doesn't make sense to me. :(
Yah that is the biggest selling point. When I finally reach audio upgrade on my mod checklist, I'll be going for the OEMA+ with dual subs, though I will be adding sound deadening to the budget. In my youth(20 years ago) I probably did around 10 full complete installed along with fitted sub box construction, half of those being my own so I feel the roughly ~$3k will be worth it. I've priced out both purchasing individual components myself as well as getting quotes from multiple shops and while I definitely could save a buck or two doing it myself, a shop is almost double for a mid tier system.
What people over look as one of the largest cost for a self install is the custom sub box, especially the one on the passenger side with the power outlet panel relocation. Now if a square/rectangular box wouldn't bother you then it would save a ton but I just can't go that route. The cheapest I found to do a quality box was $400 each and that was with no outlet relocation, meaning I'd lose that access. However I saw a few examples of their work and I'm not sure I'd be satisfied with the quality. So realistically I'd budget in $500 per side just for that. Again I'm sure I could do a good enough job for myself but I also know as a novice how much time, effort, wasted material from do overs it would be so no thank you.
Honestly I wish they sold a speaker free version where you just look at the spec sheet for the required resistance for each speaker and then add your own. I'd much rather go this route since there's really no info other than their own marketing on the quality of their speakers. However again, the T4R has some wonky speaker mounting so I'm not sure if the OEM+ speakers have the mounts already built in as part of the speaker's frame or is it a separate piece.
did you buy from tacotunes? which speakers did you go with? I replaced the dash tweeter with the 3.5" kicker tweeter and wouldnt mind replacing the remaining speakers.
Amp?
i was a early adopter. sounds great to me. just sucks that they changed things so many times since initial release. my amp is the kind that has no upgrade path.
I'm ordering the JBL Enhancement with dual subs for my '21 limited.
My 2012 F150's factory sony system was worlds better than this JBL system.
I did the speakers sub and dedicated amp kit. Plug and play was important to me as well as reliability and keeping the stock look. I’ve done a ton of car stereo installs but I just wanted clean and simple as this was my first new car. This was that. Fishing the wire behind the dash was hell. I don’t love the weird pig tail dangling battery fuse implementation. Directions were slightly out of date and they said “they’re just too busy to update them” which seems funny for a company focusing on DIY but whatever. Imaging took a second to get used to but now I like it. (I work in audio production). But over all it’s clean and loud and just what I want. I don’t need to set off car alarms. Curious what that second sub would add though.
I bought the system because of the sound from the second sub. I was able to preview it at a Toyota show. Pink Floyd's intro to "Welcome To Machine" sounded damn good. I'd still like to get it but the subs are in the way of most drawer systems.
Almost went with OEM Audio Plus for the plug and play feature, and got self into the audio rabbit hole and decided to go with Hertz DCX 87.3 (3.5"), DCX 165.3 (6.5") speakers, with a JL 8W3v3 sub in a Toyota OEM sub enclosure . I also installed Stinger Roadkill on all speakers, and Kilmat sound deadening to take advantage of the opportunity while panels were off. For head unit plug n play I went with Trailgridpro's Sony XAV7000 which comes with built-in amp (45RMS per channel) for door speakers.
Speaker brackets are Metra and the wiring adaptors can be found on Amazon.
Yes, requires a bit more elbow grease, but am VERY happy with the results.
seltzernator
