Anyone have pics BFG KO2s 265/70/17 stock rims no lift?
Really like those RCI sliders. How much rocker ground clearance did you lose? Not planning to lift mine and it already looks like it sits relatively low.
Thanks,
JDG
3" from the bottom of the rocker to the bottom of the RCI sliders. There are sliders that do better than that, but they are more expensive and I'm not sure they would be DIY install.
Since this photo was taken, I've added Bilstein 5100 set at 1.75" in front and 1" spacer in rear. This config with tires around 40psi gives me 15.5" from the ground to the bottom of the sliders. When I air down the tires, of course I lose more clearance. But this works fine for me. On "blue" trails here in CO I do hit the sliders and skids 2-3 times per trip, but I can't fix that unless I go with bigger tires. And I'm not ready to do that.
Here's ours before the lift sliders and front end swap.
Guilty as charged...I'm a RWL fanboi :D If my Falken's had the option, they'd be RWL out too.
My dad had letters on his 92 ford truck and I've always liked the look since then. I didn't expect them to look clean with the chrome on the LE, but that's a nice combination.
Here's mine. I run white letters out because I hate being able to see white letters inside when looking at a vehicle.
IMG_20170411_093734_zpsynduwkll.jpg~original
A couple of questions for you guys that run 265 TA KOs.
1. Are the stock sized beefier KO2 tires going splash rain/mud onto the side your trucks? I had 285 TA KO1s on my previous lifted 4runner (I had broken off mud flaps though) and the rain/mud over 11 years and noticeably wore down the paint and finish over the years due to the over splash. Will it happen in this case with stock sized TA KO2s (with or without mud flaps)?
2. I just bought a brand new 2017 TRD Off-Road recently, and im thinking about getting 265 ta ko2s, did anyone go this route and then go for two inch lift after down the road? Will the 265s make the truck look a little weird?
Here is my 2017 with 265 KO2s and TRD wheels. I will probably go with a minor lift in the near future.
I like the white letters out better, too. So, this is stock ride height and 265s? Looks awesome, btw.
Yes, all stock truck, 265/70/17 C Load KO2s. I run them at 38psi and it rides like stock.
I prefer the white letters out on BFGs because their font is very distinct. I probably wouldn't run something like a Cooper white letter out.
I'm so pleased with these tires that once they need to be changed I'll put one on the spare rim and buy four fresh KO2s.
265/70/17 BFGs on no lift. Will be doing a lift soon though!
are these 265? I have the exact same truck only everything is stock right now. first step is to get ko2's. torn about 265 vs 275
Yeah they are 265, I went with them since they are the lighter weight C load. I am very happy with them. Since that photo I have added a lift, even with the lift they still look plenty big.
Before Lift Install:
rx2G2NRku-jvk8fXNugwB1yELozQQOBgBI0qBZTDUZkggK_e_OqJTrVAlRFjmCEg43XWOyGZ-DRqxa2lA89T2-56WEEESZlz3WmzhvdK8RkASQSgYlj4fvujjnMY9V1RX0T8czekBBHWq-fe4hn4DE0149o8pVqgGd1ivMLkgHVIsD9KU8drDgKCJptH8MIOrhudFaH1972DZMzFAAVEO-KX5Cip0V9-hRqsGuwMrakyatp4Gfvpq1dMmldil-27iRmUBMD440EexPrqYmBncL7tn85a1X9ZElW-Hq_cWieTeAwujqdlvpE6WZQx7d0Ym0IB1ARcmjr7pa1xv8i_NxVs1V4wqIb8FDDV1KMWinPottiyj1vBz7IVzvfKe2bcpwP321-U2vrnEj699g9c1rM7wvM5aThhBI33H1MyAC5WKsTHDcrqf0461wPDI4itEgjmBCZEdTT2dGe7dIBWAnKpob9udQK4QGy4sPEzLjWXLL19d4HLkOePAba0T3OQJl75EeXvkv16er12PCcDmYoirc8fgBkC-lGJ_bT2wcApNeKW1F7KTOKi0VHzesphkNw1YuZc4lQRBacdMDNsvUkG4u4cTprGIBwQ6s6WmBAAyAmEapdQEEXivsTsfcJD=w1230-h923-no
After Lift Install:
7YbT7VnSCiQsGf-1u-jVr-uTJRiIbWgaq7eZyPrzaDUM82RMpzlK17Afv9N9zeW4xIau98s259Nc1u4bQQieywxz18R-FYwTisqPsgxwQGA5y1A-0BVNZ7wEf2WfYWfkNTSMxMGX-474fC7CsUFdL6tEciZtxIcoyPvMcXSg1X3jr1j5q9du9tcAkpaQDk90ActdIs7JmmW15uvEnkM6X7lMGhdVZ3_1JcCKJl4phY-7fun-1dHCIbhWZ-MyErVsp1pv_WJ43CLZSmlC0d-wwfsj_mBRuf4SM6SR5qXQIqc8qFgX9AkKlo8PjKWsHLaJqo0ziiaDZnNZxiaQelkcp-KqnJmdGy37hYOV77fnAlxjvR7PkxahimiKF72iziPzkRLq3tuIJ1JSTYVt9j4tcTqImF6C1Fm8vN8BTSHLpjpgIYJwl-g0ghWUG0xY_xyOWqp-KR_4N7b5vVEO8JJsyCmxxNtuKIzM5muQ8XG7L0tcy-LQQffInibtc7hqEGQjnz8fG1ckLyDaNA8oAjLVpwYkIIfs0XRXSqmEX8Cu0GXC7z-VClXrtOxOx0MGS-5oYFlRLX_MBNh6Q_twXEbsuMFgjpg1-FQg1ZN2FZLJgrBmod5l2qBYzv1nhXgUKaPZ=w1230-h923-no
2018 4Runner TRD Off Road Premium (with KDSS), RCI Full Skids, stock wheels, 265/70R17 BFG KO2, SPC UCAs (25480), Front 2.5” Lift Bilstein 6112 Front Suspension Kit (47-259768) / 1.5” Rear 5100 (33-187174) & Wheelers T13 Rear Coil.
After Lift Install:
pictures are broke.
Mine - doesn't really qualify as "stock" suspension as I swapped out with the TRD Pro suspension. But...close enough looks-wise:
265/70/17 KO2s not stock rims tho. SCS Ray10s
