Anyone make an all Aluminum Radiator
mrtucker80
I just got my Shrockworks bumper on and I want to build a skid for it but that crazy bulge for the radiator tank just ruins the front lines, so I started doing a little research and discovered that if you use a 3.4 v6 MT radiator then it is several inches shorter. Not 100% on overall dimensions, but I know it is enough. Since everyone abandons the radiator mounted tranny cooler anyway then it just seems like a no brainer to just get a shorter radiator with a B&M cooler.
The Tacoma guys use them when they do SA swaps to help clear the spring hanger. Several folks sell the short body plastic tank units but I am looking for an all metal unit to go in just because it seems if I am going to go to all the trouble of doing all this work that I may as well try and find an all metal one.
Bump to the top...
I am guessing with 73 views and no responses then the answer is no. Guess I will look into a KOYO 3.4 MT radiator for my swap.
Hey Mr.T u can try Four Seasons Radiator in Gallaway TN. Gary Bell is owner and personal friend. He specializes in making Aluminum radiators. Number is 901-385-1900. U can tell him I (john kesler) gave u number and info. if u like. I know u will be satisfied. hope this helps u
Thanks. Would he need to have the donor vehicle handy or do you think he could quote one over the phone. I know what a new OEM one would cost me so having a quote would give me a good idea. It honestly doesn't even have to be all aluminum, just all metal, brass, copper, etc.
Mr T sorry so long getting back to u been out of pocket. No need for doner car just tell Gary what kind of car and what kind of radiator u want and he'll do the rest. Hope he can help u with this. Thanks John (tkss396)
Anyone interested in an Aluminum Rad
Hey guys, bumping back to the top.
I talked to the guy at Four Seasons today and I am thinking about having them build me a custom all aluminum radiator. It should be pretty much a bolt in deal, going to have them eliminate the trans cooler since I am going to run a B&M, which should allow it to be 3"-4" shorter which should be about flush with the bottom of the frame rails. I need to get by and have him take some measurements and was curious if anyone else might be interested.
Price will probably be $450-$500, he just took a shot at it today and will probably firm it up once I have been able to sit down and actually iron out the details.
This not a group buy or anything, just thought if anyone was interested that I would share the info.
Thanks,
Matthew
I had not, but I checked them out after you posted it and they make Tundra, supra, corolla, celica, cressinda... but no Tacoma or 4Runner.
I have found them for up thru 95 pickups and 4runners, but no one seems to make a full aluminum, or all metal radiator for the newer models.
I called Griffin after finding a part number on Pirate that turned out to be a part number for a custom one he had build several years ago and they said that they could build me one, but would need a template. They are in Cali and I am in TN, not gonna happen. Called around locally and no one seems to build them in town, called Four Seasons and they said they could build one but also needed some measurements to work off of. They are only a couple hours down the road so if I can find a minute to run down there, or find one to send them to use as a template then I can have just what I want built.
Four Seasons was also about $200 cheaper on their phone quote then Griffin, so that helps.
I will keep you guys informed.
I looked for awhile after I broke off the plastic overflow spigot, the closest I came in my searching is this:
Csf 2304 Radiator : Amazon.com : Automotive
the csf 2304, is on paper your best bet, however there might be a local radiator fix it shop, hoping the dudes there are chatty, I'd ask about an all metal salvage yard swap, who knows maybe they know about that "88 Volvo curmudgeon" that will fit right in...
Thanks,
Matthew
Hey Matthew,
Just wondering how your search is going??
Thanks...
Hey Matthew,
Thanks...
For now it is on hold. I need to do my timing belt and want to do the radiator while I am at it, so for the interim I have ordered a KOYO C1774 which is about 2" shorter than the stock rad. It is a two row unit designated for a tacoma that should, from my research, bolt right in. It should be here next week and I will keep you posted. Since most of the custom folks wanted some kind of core to work from, I figured I could keep the old one to send off to use to make a custom one at some point in the future.
Sorry, I really wanted this to go forward, but for now I have put it on hold.
i have googled and cant come up with the answer, i also dont have enough posts to create a new thread so hopefully you all can help me. does a 2nd gen 4runner radiator fit in my 3rd gen 4runner? there is an all aluminum radiator for a 2nd gen that i can get for cheap but id like to know if it fits. i recently towed a raptor on a small trailer and it got up to 235. it was 110 that day but still. ive been told that it could be my radiator with 270k miles on it.
I'm going through the radiator swap thing right now for my SAS.
I would venture to guess that the 2nd Gen radiator will not be a bolt in swap for your 3rd Gen.
There are 3 sizes of radiator for the Gen 3 models....and those have sub variations based on whether or not you need a built in trans cooler.
Rock Auto has dimensions for various radiators....but not bolt patterns.
The 3 sizes for the 3rd Gens are 18 11/16" core height, 20 3/4" core height and 22 5/8" core height. The largest one is ~28" tall overall....the medium is just under 26" tall and the smallest one is just above the bottom of the frame rails.
thank you for the reply. i dont need the one with the tranny cooler. ill try and get the dimensions of the 2nd gen radiator. If not im sure a stock radiator would do. i dont do much towing. my quad and trailer together are probably around 1200 lbs. just figured id try it while i had to get one anyways
EDIT: well it seems the 2nd gen radiator is smaller at 18 3/4 inches tall and 20 3/4 inch wide core. they are 1/4 inch thicker also
2001ATL
