I run E-lockers front and rear. They are the original pin design (vs the collar design used on Dana axles) in a 14bsf and a 10b. I have never had a single problem with them, but you have to understand how they function in order to not use them incorrectly. With ARB's, once there is enough air pressure and teh splines line up, they lock and stay locked until the air pressure is released. Eaton's design uses a magnetic drag clutch to operate a ball ramp assembly, which forces the pins/collar into engagement with the side gear. The thing is, it takes approx. 120 degrees of carrier rotation to lock the pins/collar. If you try to thrash on it before it is locked you risk damaging the pins or collar. Likewise, trying to engage it during a wheelspin situation is bad. Also, any time you reverse the carriers rotation (either going from forward to reverse or vice versa) while locked, the locker will unlock and then relock, with the whole cycle taking approx. 240 degrees of carrier rotation. Once again, wheelspin or hammering on it before it is completely relocked can break shit.
