Anyone run aftermarket wheels that fit Nissan and Chevys?
Millerad1651
Found these on CL today. Asked the guy, doesn't know the backspacing. I asked about the centerbore, and he said its huge, fit his Nissan. The wheels he got to replace didn't fit, so he had to bore them out. He's had them on a Nissan 95 4x4, and a Chevy.
They are 6 x 5.5, so I'm good there. I have stock calipers, so I should be fine with fitment on those. I asked him to measure the backspace when he got home, but I'm thinking these would work. I read somewhere that most aftermarket wheels are bored out to fit largest model...that true?
Any thoughts?
16" aluminum wheels & tires 6 LUG
I'm pretty sure they will work. I ran some Mickey Thompson classics that I bought from a guy running them on his Chevy. I would make sure the backspacing is 4.5" or less otherwise it will narrow your stance
I see a nissan frontier every day that has the FJ alloy wheels on it. Just thought i would add that.
From what I can tell in the pic, the centerbore is exactly what it should be for us. The only thing that worries me is the apparently massive amount of backspacing. I am guessing you would need at least a 2" spacer just to take the wheel back to near stock backspacing.
Ya, it does look like a lot...hopefully its not though. He's going to measure for me. I don't mind running a 1.5in spacer, but nothing more than that.
a larger spacer with a wheel like that would not be bad, as it would not push the wheel so far out that it would "arch" when turning via steering... both ford chevy and dodge all run like 8" +/- spacers on their dully trucks up front, but the wheels have a lot of back spacing so it evens out.
but yes those wheels should fit, they they look like they will probably narrow your track without wheel spacers(thats if you can fit them without wheel spacers. -chevy, nissan, isuzu, toyota all share the same bolt batter on 6 lug wheels. and if its an aftermarket wheel you shouldnt have to worry about the center bore/hub diameter
i run stock wheels of a titan and had to machine the bore diameter out a ton to get over the hub, but usually the aftermarket uses the largest hub diameter as a standard so they dont have the same wheels with multiple hub options. the backspacing doesnt look to bad because there the mounting surface actually is. the lugs will be resessed into those wheels alot. i say theyd fit. only takes 10 minutes in the guys driveway to try one though
Thanks for the info guys. I'm going to look at them Saturday...hopefully they work and I can score anew set of rims for $150, and sell those tires for some of the money back.
Philthyphilthy
