Anyone running 883s on Tunrda 5100s?
hungryeddy
i got a lead on a used set of 883s. i don't have any weight on the front end (no bumper, winch, ect.) but since they have the tendency to sag down a bit (these are a year old), i figured these might work. any thoughts?
or any other OME springs on a set of 5100's from a tundra? after reading that the taco 5100's aren't the best for a 3rd gen, i much rather find some springs that will fit the tundra 5100's.... the TRD springs are way to hard to find and i'm going to explore other options before i buy them new.
The Tundra coils have a larger diameter than our 4Runner and Tacoma coils. Therefore I am not sure if a OME coil (such as the 883) will seat correctly in the Tundra 5100's.
I'm running 5100's with 883's up front. I'm not sure which 5100's they are (which doesn't help you much), since I had them installed at the Truck shop in SD. I have a 2whl without any weight up front. I do feel the extra 'stiffness' when climbing speed bumps, but otherwise they handle brilliantly.
There are Tacoma/4Runner 5100's AND Tundra 5100's. Tundra's have 5 perches for adjustment, the Taco/4Runner ones have 3 perches.
Tundra it is then, I'm running on the 3rd perch. Tried to run it higher, but the ride was way too stiff.
photo1-2.jpg~original
