Anyone running OME springs, 5100s, with bumpers?
Javelin
Im getting close to getting my shrockworks/cbi bumpers and was wondering what Level to Set my 5100s at. Currently theyre at .85 but what should i Set them to once the new heavy load springs and front/rear bumpers Are on?
Anyone this Combo? I want it level as possible.
Any imput would be greatly appreciated. Thanks!
I believe I've read to use the 2nd heaviest if you have a v6 with bumpers and the heaviest if you have v8 with bumpers. You should run the heavy ones in the rear as well.
I don't think the bilsteins are warrantied if you use the lift settings in combination with lift springs. You should get almost 3" out of the springs alone if I remember right. Leave the bilsteins set to 0.
edit- I think it's more like 2.25-2.5" with bumpers from the heavy OME springs.
So your Saying use the Medium OME springs in the front and the heavy OME springs in the rear?
How much does the CBI Bumper weigh loaded up with all the goodies? Gas can, Jack, etc...
CBI's bumper by itself is 135lbs. But if you add the swing arm (70 lbs) along with all the other options and fuel you're looking in the 300+ lbs range.
Def going with the heavy springs But Can you even run front OME springs with 5100s?
On ARBs site they say OME front coils can only be installed with OME Nitrocharger strut and coil seats.
Deno91
