Anyone running Tundra 5100s and Toytec/Eibach Springs?
I have the tundra billies (1st perch) and the adjustable toytec eibach coils they only give me 3 1/8 " of lift and I couldnt turn the spanner wrenches anymore. My measurement hib to fender are 26 1/8". I also havw a 3" body too.
As for the ride quality very nice like everyome said a tad stiff.but not as bad as the 2.5" leveling kit spacers I had on the 99 tall coils. Now that was a shotty ride.
I was think about adjusting to the 2nd or 3rd perch and then crankingthe coilovers down so they are not maxed.
:redbrick: Got it, the confusion was that my '99 already had a factory 1" lift, which I took out of the equation...
kinda new something was wrong when sn0wrunner posted.
This means the fj80 coils have to be replaced @&#$^#@*
Think I'll have a beer or 10 tomorrow. Feeling pretty stupid right now.
:frusty:
Thanks guys
i know this is an old thread, but i figure i'd update.
just got my truck back, lift is tundra 5100's (5 perch) with toytech/eibach up front
and landcruiser 8-wraps in the back.
I had it put on the bottom perch based on toytech's recommendation and this is how it sits....... I'll obviously let it settle for a bit and see how it looks, but its quite a bit of rake.
Those 8 wraps should settle. I have the same lift but my 8 wraps have 200k+ miles on them and not nearly as much rake. I also keep a subwoofer and tool set in the back.
I'm doing this exact setup also but now I'm concerned. Are you running the 5100's in the rear too? Any spacer in the front?
I also run the tundra 5100s with the eibach/toytec lift springs. I have mine set on the second setting and have lc 8 wraps in the rear. It rides great and has broken in pretty well after a couple thousand miles. I recently put a tjm front bumper on but it's currently sporting no winch. It didn't sag nearly as much as I would have thought after mounting the bumper. I can update with pics later but I like the way it rides and the stance so far.
Here's a pic without bumper, it's off right now prepping to put the winch in and finishing modding it to fit with a 2" body lift. It's currently on 315 75 16 BFGs.
no spacer in the front, apparently there is no room with the tundra struts.
I'm also running 5100s in the back, i used the part numbers from rickashay's lift thread.
Now that I have my 33's on the truck, im happy with how the rake sits, and im told it will settle.
I have the Tundra 5100's with the Eibach coils up front, also running a 1/4" toytec top spacer with them with the 5100's on the 1st perch. Previously I had the TRD Tundra coils with my 5100's on the 3rd perch. I like the Eibach's much better, they give me more lift to match my 8 wraps in the rear and ride much better than TRD's but that is because the 5100's are on the 1st perch. They are stiff but not too stiff, also I have no extra weight up front.
What is the part number of the springs you are running?
Front spring part number?
What is the part number for the springs you run with the Tundra coils. How much lift did it give you? What perch did you set them on? Thanks!
Tx470
