Anyone towing an enclosed car trailer with the V8
emoore924
Member
I'd like to hear from anyone who tows an enclosed car trailer with a 4th gen V8. I have an open car trailer and have towed that for years (and a boat) with my V8 Explorer. But now I have an 05 4R with the V8 and a tow package and was thinking of upgrading to a 20' enclosed trailer.
I'm looking at 7000lb gross, weight distributing hitch with bars, brakes on both axles and a tekonsha prodigy brake controller. All my towing is up and down the east coast.
Anyone towing anything that big? Anything special I need to watch out for? I'm experienced at driving a tow vehicle.
I towed a fully loaded 6'x12' trailer with my 05 V8 with no issues. With everything you plan on doing, I doubt you'd have any issues with pulling that size trailer.
Thanks. I'm just thinking that an 8.5x20 at 7000lbs with those big slab sides is going to be at or near the limits of what this truck can tow. Just hoping to find someone who is towing something close...
I have done something similar, but not exactly the same. A few years ago I had an 05 Tundra 4x4 Double Cab, with the same 4.7L V8 that is in our rigs. I had the factory tow package and a towing capacity of between 6000-7000 lbs, which is on par with our 4Runners (the Tundra was a bit heavier). I was moving across the country for a military transfer (NY to WA), and towed a 24' enclosed car trailer all the way across the country. I will admit that I was overweight at 10,000 lbs in the trailer alone. I used a weight distributing hitch, dual sway bars, and a Tekonsha Prodigy electronic trailer brake controller. The truck pulled it beautifully. I kept it between 60 and 65 for the entire trip and never had an issue with sway, even from passing tractor-trailers. My milage for the trip averaged closed to 11MPG, with my lowest being around 7MPG while pulling up the east side of the Rockie mountains (I went across I-90). I even pulled the trailer up hill to Mt Rushmore so that the wife and I could take in the sights. (I had planned on dropping the trailer at the hotel first, but I was running out of daylight and took a chance.) I was only able to maintain about 20-25 mph up the steepest part of the grade, but I had no problems with transmission temps. I was monitoring several parameters with a Scangauge and the trip was made in late October.
The bottom line, your truck will probably do fine in the short term. Obviously, extended hauling at/over the vehicles GVWR will do a lot more wear and tear and result in more maintenance (either preventative or corrective, whichever you prefer).
My advice would be to lease a Tundra if you have the credit to do so, and can resist the mod bug. This will allow you to trade in before the added wear and tear from towing start to take a toll on the vehicle. Just make sure that you can accurately estimate the milage that you'll use and buy them up front. I just leased a new Rav4 for my wife with 16,000 miles/year. If we do end up going over for some crazy reason, my penalty rate is $100/1,000 miles.
I hear ya on the tundra but I just got the 4r so it is what I have to work with. Towing is what I bought it for, and towing it will be.
Still hoping for someone who is towing a larger enclosed trailer (or even a big boat) with a 4R. Anyone?
I'm sure it will handle, but for how long? What would be the Speedos towing under maximum capacity? I'm sure Toyota said 7000lbs under easy conditions, no hills, smooth roads and what not. I wouldn't want to max out towing capacity.
youngrk
