Anyone with just a 2" lift?
I've got OME 880's in the front, OME 2906's in the back with Bilstein 4600's (HD's) all around. Very happy with the ride and the height/looks. Here's a photo from today.
FJ Cruiser coils are another option for the rear. They have a slightly wider diameter, but seat on the perches just fine, though on the upper perch you need to hammer it a tiny bit wider. They offer somewhere around a 2" lift, have a good spring rate for these trucks (180 lb/in I think). I ran a pair in the rear for two years and had no issues.
99 tall springs up front, 906's in the rear with KYB gas adjust shocks.
My boat is hooked up in the picture. Gotta love how the 906s handle extra weight, hardly sink at all.
Brand new Falken wild peak AT3W 265/75/16.
Sent from my SM-N950U using Tapatalk
So I'm looking under my truck today and see I have Bilstein shocks? I thought it was all stock when I bought it. Do I already have a lift on this truck? Here's some pics of the front and back. and what it looks like now.
Those are Bilstein 4600 shocks, which are a 'stock-type' replacement. Your truck looks like it is at a stock 2000 height.
When measuring height of the truck, measure from the center of the wheel hub to the fender. That removes tire size as a variable. Around 20" is considered 'stock' ('99 talls sit around 21", early and late sit 19-20", depending). My '99 2WD (not a '99 tall truck..) was just over 20" all around when it was stock.
-Charlie
I've got the TRD tundra coils on 5100's on the lowest setting up front and OME 906's with a 10mm coil spacers on each side with 5100's on the rear. My hub to fender measurement up front is 21.75" and the rear is 22.5" with a case of water and a stroller in the back. As far as ride quality it rides as good if not better than my 2015 Tacoma TSS. I highly recommend this setup.
2" ome coils w/ 255/85/16s. Took a bit of work inside the fender wells to make everything clear when its flexed.
Haha I’m guessing “bit of work” means hammering it with a BFH?
I love the look. How’s the power with those tires? Did you take an MPG hit?
Hahaha yes, a 3# hammer helps quite a bit. From 265/75s to 255/85 I did notice a bit of power loss. It's not terrible though.
Thanks, I love the look so far, just hope it doesn't rip any fender flares off on the trails. I just switched last week after ruining a sidewall on my wildpeaks. It's not my dd so I haven't put many miles on them yet. Based off of the power loss Im thinking it lost some fuel economy as well.
Okay, I'm putting my package together of what I think I'm going to get. Anything else I should add or change?
OME 2906 for the rear. $167 pair
99 Tall's for the front $295 pair
BIL 24-249966 X2 $165 rear
Bilstein BE5-D558-TO $175 front
it all adds up pretty fast.
I just used what the 4 wheel parts place computer said. what should I run?
Its up to you. Here's some info from Wheeler's Offroad, and there is tons more info on here if you search.
https://wheelersoffroad.com/i-30857...r-1996-2002-4runner.html?ref=category:1388357
Basically, the D558's were a custom front shock made for an aftermarket company through Bilstein for the Tacoma. Since then, Bilstein has come out with a 4Runner specific application. They are slightly different, but both work.
-Charlie
