SpeedyKevin
Plan on installing mine this weekend but after reading all the post I’m pretty worried has anybody’s Kit successfully worked?
Mine has worked perfectly. Got to test it out on the trails and it definitely helped!
If you plan to post to Classified forums, you must follow these rules, or your post will be deleted.
Mine has worked great from the first day of install. I kind of waited a bit after running the wires to the front camera to actually install the front camera because I needed to remove license plate and bracket to get drill in. It have all worked from day 1 though. If you have problems I would check the connections you have to make first. I used the solder seal wire connectors listed below and they worked great.
https://www.amazon.com/gp/product/B07T1HYJ9G/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Curious if you have the nav override in yours. I have yet to install mine but wondering if all the successful installs also do not have the nav override.
So did anyone hook up the blue and grey wires on the switch for illumination?
Install complete. Nice that the front has the reference lines.
My front doesn't have reference lines. now I' jealous.
Camera install - Mirrored Image and Guidelines
– Anytime Backup Camera
Did you use one of them from the kit?
Yes sir I did.
Any chance the wires got cut? A had to cut one to do away with the reverse image, but the other is listed for the reference lines.
No sir. I took my time and made sure everything was done right.
Noticing my satellite radio cutting out a bit more since install. If it keeps up i will pull the plug on this mod.
