Arb bumper fast blinker
4runnerAzGuy
I just recently installed an ARB bumper. I hooked up the lights and the blinkers flash really fast like a bulb is out. I'm guessing the arb lights for some reason have less resistance or something. Is it going to do any harm to leave them? The fast flashing doesn't bother me but I don't want to pop fuses or something.
Mine did this after I installed my Addicted offroad front bumper. If your turn signals are LED the system thinks the bulb is out. I was told you can replace the fuse to remedy the issue but I dont think it's worth it.
you need to add in a resistor, or change the flasher relay to a constant rate relay.
technically its considered equipment malfunction and you can be pulled over/ticketed for it.
Tridon EP35 is the relay you need. Turn on the hazards and feel for the clicking relay. Top side of your fuse panel under the dash. Pull it out and replace it with the EP35
leolediola
