ARB dual compressor mounting location options?
Mine is in the engine bay. 99 so no TB mounted cruise. Unwrapped the wiring, and relocated the ABS relays sideways. Then moved the cruise control by fabbing up a mount for the compressor and ABS to ride on. Bracket has a heat shield to block direct heat from the exhaust manifold.
Works bueno.
Can I see some more photos, with one showing the ABS? Thanks!
To relocate the ABS, did you have to redo the brake lines?
Sent from my SAMSUNG-SM-G890A using Tapatalk
I first wanted to put mine in the engine bay, but because my ABS and cruise control are taking up all of the precious space on the passenger side, I ended up going with the rear cargo compartment. And I think it was the better option, anyway. Much less dust back there.
Just installed it yesterday.
I used a couple boards under it to support most of the weight, so it wasn't just hanging from the plastic of the cargo compartment.
that's a hell of a tight spot.
I mounted my single arb compressor in there.
It fits there with the ABS module in the factory location. The ABS relay's had to be relocated. I can try to get a picture of that.
Ah, I have a feeling your engine bay is different than mine over there. I think I would've had to relocate the ABS to fit it in. Mine's a 2000.
Mine is a 99. In the pic above you can see the ABS sitting behind the compressor bracket.
Here is a shot of when I was re-looming the cruise control and ABS relay wires.
And here is a more vertical shot
Perhaps the perspective is throwing you off. The compressor sits up pretty high. As does the cruise control. In order to clear the abs in the factory location, the cruise module was moved up so it just barely clears the hood.
Also note that the compressor is pretty far forward. Originally I got an injen intake but it was so noisy I ditched it and cut down and fiberglassed my factory air box to clear the compressor.
I didn't update in this thread, but I put mine in the rear cubby hole on the passenger side.
I think the passenger cubby hole would be the most straightforward, out of the way option. But... if you are creative, and willing to fab and cut into your interior body, then your imagination is your only limitation.
The pic in the one you posted has a fair amount going on. I would be interested to see what it looks like buttoned up.
I could also see fabricating amount to bolt it to that you could in turn mount somewhere out of the way in the back. I've seen a few people do this that have installed a first gen roll bar in the back cargo area. They just mounted it to part of that. I think @the_great_him has something like that going on.
Your install looks great, thanks for the pics.
I don't think I'm willing to give up that storage cubby, so I'm deciding between a single and dual compressor depending on what I can fit behind that driver's side panel. I've seen pics of the single and a VIAIR 450c (IIRC) back there, but not sure if the dual is possible. I'm guessing it is and will probably just order one if I don't hear anything definitive; worst case I make room under the hood. Thanks again.
Nice install, do you have any electrical in the rear of the 4runner or did you run all the power wires back to the engine compartments?
If I recall correctly, the previous owner of my 4Runner had some heavy gauge wiring run to the rear for a big subwoofer, which I tapped into for my compressor and ARB fridge (I had removed the subwoofer and amp).
how hard was to get the wiring all the way to the front? how many pannels did you have to remove?
It's a bit of a PITA. My friend, who is good with electrical work, had to extend the control loom and run the power cables from battery, back toward fire wall, over to passenger side, through firewall, under plastic foot sills, and to the back cargo area. You have to take off the back quarter panel trim to run the wires through. To mount it there, you need to take it out to work on it. This requires taking the passenger side rear seatbelt that runs through that trim piece out as well. Also, there is a pre-drilled pass though behind the trim panel the goes to the rear passenger body corner that is big enough to run your air line through. (you're welcome) Hahaha.
Now, if all that didn't scare you away... The twin is heavy. That plastic is light and not great for supporting a mounted compressor. It "fits" in there and looks good, but it is noisy. Not the compressor running or anything. I mean, think about it. If you are pumping up tires, who the hell cares if it is making noise. It only runs initially to actuate the air locker, but it doesn't run all the time. If it does, you have a leak. If you wanted a nap, stay home. HAHAH. But... This mounting solution will cause the two plastics between the cubby hole and the quarter panel trim to "chirp" all the time. This might drive most normal people insane. I've gotten somewhat used to it.
TLDR:
Here's what I'd suggest: not in any order
Option 7: Build a bracket that puts it out of the way, (maybe above wheel well). Give some thought to future proof any rear storage plans for later. I've seen this. Fab up quick disconnects for power and control loom so you don't have to cut a bunch of wires to remove it if you need to. Ask me how I know... Maybe bake a bracket that sits in the cubby hole space that IS NOT mounted in any way to plastic.
If I could go back, and still wanted it there, I'd fab something out of molly panel type material. I'd iso-mount the unit to the fab using some sort of rubber insulated mounting solution. I'd mount it over the passenger side wheel well and make it as quick and easy a disconnect option that I could come up with. Once you run the lines without that, If you had to take it apart, you can't pass the control/power looms through the pass-through.
Option purple: Mount it in the engine compartment. This will be the easiest. You won't have to figure out how to run all that cable everywhere.
I will probably revisit my mounting later when I can. Between the armor on the outside (tire carrier) and the compressor mount on the inside, my vehicle makes a lot of noise that I could live without.
PS: I like how my TLDR is longer than the sections it offers a solution for. Hahaha
I put mine in the rear cubby as well. Put a quick release fitting directly on the compressor and drilled one large hole in the cubby lid where this pokes out just enough to connect and disconnect a long coily air hose. I already had a big power bus mounted at the rear of the vehicle (with an Anderson connector for occasional use of a receiver cradle mounted winch) so I just tapped into that, and then ran a single wire up front to the dash to turn it on. I have a manual truck, I got a center console from an automatic so I'd have an unused 'ECT' switch, I used that. ECT meaning... Electric Compressor Thing?
I also drilled some air holes in the cubby lid for ventilation - the Arb dual has a cooling fan. It gets pretty hot in use, though. Never hot enough to shut off, but the first time I used it, it got the fittings hot enough to blow out my poly vinyl line (it's pretty sensitive to heat). I got a tougher section of stainless braided hose to act as a buffer between the compressor fitting and the coily hose.
I'm just using it to air up tires at this point, if I ever added a front air locker or wanted to run air tools, I'd plumb in a tank somewhere underneath.
seltzernator
