Arb sway bar rub fix!!! Bp-51 fit kit
I got mine from total automotive performance. After they shipped it they called to let me know the wrong kit had shipped, and to let me know that they had shipped the right one. Call total automotive performance they will set you up!
Thanks. Going to just modify the ome part. Will weld a 5 inch piece of flat steel below the tube and then grind off the tube to get the clearance.
Just wanted to thank everyone who chimed in on this thread!!!! I had the same problem with my Fox 2.5 coilovers!!! Swaybar was against the coil without the relocation kit and hit the driver's side tension bracket with the relocation kit installed. The supplied spacers didn't help and I didn't want to add more.
This replacement support that comes in this ARB kit was PERFECT.
OME BP-51 Front Fit Kit | VM80010028
they have a forum discount code as well
also note this kit comes with a sway bar relocate kit as well. so price isn't really outrageous at all. This kit costs ~$40 more then the other bp-51 kit for the fj cruiser.
Thread revival-ish ..... does the FJ kit work for the 4runner?
Reason I'm asking is because I have no need for the swaybar relocate kit - I have kings and the reservoir brackets relocate the swaybar already.
need to look for a FJ install sheet for their kit and see if the bracket is vf60050027
although i think they don't have this issue. I think when i originally bought my bp-51, it came with a FJ cruiser front kit, which didn't have the piece you need.
Wow, this is actually amazing. ATTN: Icon owners here is your fix for swaybar rub! A bit late for me as I already modified my OEM support brackets. Good to know that there is an aftermarket solve though.
Found this old thread and just ordered this kit hoping it does the trick. Had my 2019 4Runner non-KDSS lifted with Icon stage 2 this week at a local shop. Was perplexed when I noticed they had dropped the radiator supports by adding spacers/washers. Is this normally required when using Icon lifts on the 4Runner?
9cEAMKl
9cEAMKl
thats what some places do to give the sway bar more space. This kit will do the trick.
Thanks Ray I appreciate the response. Is that OEM part just a radiator brace or does it serve a suspension purpose? Also Just to confirm I just need to do the drivers side and passenger is good to go with the OEM?
Thanks again!
Thanks again!
yes you only need 1 of the braces. its supposed to have structural purposes unless your replacement skid plate is designed to be used without the radiator brace.
So I have had no luck finding this kit that shows the bracket (possibly picture is of FJ kit). Anyone order recently? Link or info would be appreciated. I did the 2.5 icons with the washers as spacers and it barely hits bracket on drivers side.
Bumping this thread *hopefully*, because I’m in the same boat. 2020 TRD O/R with no kdss. Kings 2.5”. I just ran out to grab some fender washers to attempt a quick fix so I can at least drive her. I never got a drop kit or anything with my suspension.
did you install a sway bar relocate?
Yeah, I ended up just throwing a stack of washers on each of the four bolts going through the skid plate. The front two go through the infamous skid plate/radiator support brackets. I think I used 8 washers stacked up to get about an inch of space in there.
My plan is to just weld the washers up to make it easier for oil changes until I find a skid plate that has a door for the oil filter.
Works just fine. No need to buy any kit of any kind.
youngrk
