ARB Twin Compressor mounts... up to date info?
classic72
I have read all of the posts back in 2012 from Jango's bracket from Agile and an alternative from Slee, but I can't find any up to date info. I will be ordering the ARB twin compressor and just curious if there is an off the shelf solution to mounting these yet in the PS Rear firewall area (whether on the actual firewall like or the fenderwell) or if it is all still custom fab?
Any new solutions or installation tips??
Air
Twin ARB compressors sounds good, I took a less expensive route since all I do is air up after a run.
Home brew CO2, half the cost of a Powertank
I have the only known second Agile bracket. They didn't make a jig and had a hard time making mine work. I'll reach out to Peltfreybilt and see if I can get it added to their list of possible 4Runner products. They are shopping for a 4Runner right now, so they may be interested. Southern Speed may also see it as a way to set and early foot into the 4Runner market. It's not a complicated bracket, but it needs a vehicle to make a proper jig.
Okki
Two pieces of 2" angle aluminum and a single 2" piece of flat.
I really wish there were a after market bracket but this works, 6 months, so far so good, uses factory mounts with no alterations necessary. No room for a tank though. Considering putting one... somewhere
sorry for the crappy pic..
I have thought about C02 but remember the hassles of traveling and refilling in the middle of nowhere when playing paintball (before I upgraded to Nitrogen... Which solved the ice and pressure issues but not the filling part). In addition ARB Lockers coming soon.
Thanks Okki for the info. I wondered what the conclusion was.
Thanks JRandom... What are the hardware specs to mount there nut and bolt wise and to get it raised over the harness?? I was originally picturing something mounted to the actual firewall/fenderwell...
I am not sure there is enough room to mount it flush against firewall.
I just used a single 1" threaded barrel to level out the bottom bracket. That gives enough clearance after you relocate the power inverter feed line.
