Are rear sway bar links the same size as the front?
OpenYota
I have stock height 2001 and my rear sway bar end links are due for a replacement.
Are the front and rears the same size?
I’m having a little trouble differentiating which ones to purchase online
Fronts are longer than rears. A common thing that dudes do when they lift their trucks, is swap their front sway bar links to the rear, and take links off of a 2nd gen 4runner to the front, which are also longer to correct for body roll. Someone let me know if I messed that up :whistle:
You're right, but the OP is at stock suspension height. When you order these, you order either Front or Rear links for the reason you stated - they are different. I always saw them listed for sale as such.
Okay, thank you.
I’m going to purchase Moog links so I can match the moogs I have in the front.
H.Sikina
