Asked for as close to 4 degrees caster as possible
kpinthebay
Member
Toyota dealer gave me this....am I okay? I know you want more but in the red?
Icon coilovers with UCAs
Sent from my Pixel 3 XL using Tapatalk
I have 4.2 and I like how it tracks and feels planted over stock. And you get clearance for big tires!
You're fine. I run 4.7 degrees and haven't had issues. And like [MENTION=167491]83Mule[/MENTION] said plenty of room for 34's!
You are totally fine with that caster. I have 5.2 and 4.7 and it drives just fine. Plus like someone mentioned earlier... it gets you a little further away from the body mounts if you wanted to add larger tires in the future.
In short, you good!
I have SPC uppers and am wanting to do the same. I am afraid that when I take mine somewhere they wont know what to do with the SPC uppers.
Two shops refused Me with SPC's and ANY lift! Try a 4WheelParts. I explained that they are adjustable to return the values to stock and they looked so confused.........said they didn't know what settings to use with a lift! I walked away laughing at the state of the idiots National chains will hire. 4Wheel will do it.
My dealer wont do one on mine.
OP, are your SPC UCAs ball joint set at the factory position?
I only got around 3.4 degrees of caster when set at factory from SPC.
Woops I guess I forgot to mention I have Icon tubular uniball UCAs.
Helps that the dealer I went to has in their showroom 4 Tacos, 2 Runners, and a Tundra with full OME lifts. One of the Tacos has a 6" BDS which actually looks pretty nice. Of course, they're all attached with a dealer add on sticker for $5,000 for "full custom suspension"
bobdjr41
