At what mileage did you change your v6 timing chain?
Now at 143000 miles. Full syn oil every 6000 miles. Never changed out the chain, and never will.
Most likely sell within few years anyway.
I thought that the 4.7 V8's had the infamous timing belt problems. I don't think you need to change a timing chain unless it needs it (hence why they switched back to a chain) because they are more durable. Or I could just be an idiot (very real possibility). Also, change the oil every ~5k ish.
what problem would that be?
203k miles
Never touched the chain and hope I never have to... still going strong and I hope it stays that way for miles and miles.
I think they would wear out after about ~100k. My Father had a GX with the 4.7 and his wore out right at 100000, as did my Mom's at a slightly higher mileage. I think (?) that the 4Runners equipped with the V8 had the exact same engine as the GX 470's.
ah. that's not really a problem/flaw inherent to the v8 engine. its EVERY timing belt engine. the belt is a maintenance item. our are good for 90k, others are only 60k. not a problem, just a different design.
I put the original back in at 170k when I did the head gaskets. It was in new condition.
Were you not tempted to change it while you were in there? I've been told that if I'm opening it up I should change the chains and tensioners.. Its a pretty penny but if I dont have to worry about it in the future I think it would be worth it.
I'm at 513,535 miles, and I still have the original chain. Also, not that this suddenly on oil change thread but I use Mobil 1 Extended Performance and change every 15k+.
That's awesome.
We just started using Mobil 1 at 160 K on our 06
Not one bit tempted. The block metal was coated evenly with a gold color of warm heated oil. The plastic tensioners were barely marked and the chain lined up exactly to the marks when re-installed. It was a one-owner vehicle driven in Nevada, so warm/cold cycles were likely less extreme than a northern vehicle. It's been 20k miles since the re-install and with 180k miles it still idles like a new car.
My only regret on the re-install was getting a generic water pump because it came with a non-metallic gasket seal, and that leaked after a few weeks which added a few hours to repair again.
averyberryman061493
