nevada
Senior Member
I am getting vibration around 55-60MPH and it goes away at 65MPH. I was always told that if you can "drive thru" the vibration, it was tire related.:noidea:
yes, that is correct.
I think it is basically inherent to the design: a fairly light body (for an SUV) suspended very high up in the air (again, relative to most other stock SUVs), with large tires from the factory. It is rather frustrating. Like I said I adore my 4Runner and it has been a great ownership experience so far, but these vibrations can get very frustrating. I am strongly considering buying aftermarket hub centric wheels to hopefully avoid all of these balancing issues in the future.
I've scheduled another round of balancing at the same dealer, I'm bringing the TSB printout with me and will hopefully confirm with my own two eyes that their machines are properly equipped.
Wait, hold up. You said a magic word. Are your tires lug-centric and not hub-centric? Did you have to put spacers on your tires when you did the brake swap?
If you are lug-centric, you're going to be fighting vibrations every time you hit a pot hole or take a sharp turn. It's just how it is. Some people get lucky and they don't have any vibration, or at least not at first. Going back to hub-centric will fix the problem.
Not sure how tires themselves can be any kind of centric... my one set of wheels are the factory split spoke 16s, the other set are later-model Tacoma 5 spoke 'star' 16s. OE lugnuts with the long shoulder that sits snug in the wheel lug holes and have washers seem to fit both styles of wheels correctly. No spacers. I'm confident that the vibration issue can be solved, it just needs a competent person with the right equipment doing the job.
OP, you basically have the right idea. Consistent vibrations are always caused by a spinning part. So your variables are tires/wheels, brake rotors, wheel bearings, u joints, possibly a propeller shaft out of alignment, rear main bearing.
I had an entire thread on this called "Jitters on bumps". Its like 12 pages long, and why I affectionately named my truck Jitters. I still have the vibrations today, and Im still convinced its in my tire/wheel balance. Im running wheel spacers which certainly may be a contributing factor for me. But the point is, after almost 4.5 years of trying to get rid of these vibrations, I still haven't. Im convinced it is still in the tire/wheel/hub balance, as frusterating as that is.
Now, as I have replaced more and more parts in the front end, it has continuously felt better and better. Like you said, a worn suspension part is not the direct cause of a vibration. But especially on these trucks, worn front end parts will significantly magnify the vibrations. So if you have any looseness in the front end, replacing such parts may help significantly. The biggest one for me was the new steering rack. Made a world of difference
So an update for everyone, good and bad news.
Good news: my service adviser at Butler Toyota was fantastic, and set me up with the master tech to do the balancing. He was the only tech at the dealership who even knew about the TSB. He even came out to the waiting room to show me the Haweka adapter. Wheels balanced out fine, the initial job was infact done wrong.
Bad news: On the drive home, while the previous, consistent vibration was gone, the more familiar one that I've lived with since I bought the truck is as prevalent as ever. It comes and goes at 65-75, hitting bumps can either stop or start it. Feels more central to the truck rather than from the wheels. Perhaps I need to take a look at my driveshaft again. I'm visiting my brother's shop in a few weeks when I travel home for Christmas, we'll see if he finds anything.
Good to hear the wheels are sorted. Question on central vibration have u by chances replace the rack and pinion bushing just curious. I am currently fighting a wobble/Vibration at those speeds. I suspect shocks. But was curious.
Without actually going to a dealer I just simply use the aftermarket option at Rockauto.com and choose the non poly
Looking forward to your results!Got a call from the shop, they couldn't balance the shaft as it was, rear u joint was infact bad. Once that was done they ran it again it and it was .030 out (slightly bent I guess???), so they balanced it.
Picking it up tomorrow and installing it, fingers crossed!!
