ATTN: Fabricators - Fog Light ARB Bumper Idea!
HappyHooligan
Hey Everyone,
So I just got an ARB bumper on my 2000 Sport but I lost my fog lights when I lost the original sport bumper.
So, I'm thinking of having a bracket that fits on these three bolt holes (just use the outer 2), have it bend down an inch or so and bend 90 degrees with a hole that you mount an aftermarket Small fog light on. Close to the original plug too so I can access it with my steering wheel light switch.
or have something similar on these outer access plate bolts but I think the other placement would offer more protection from off-road use.
What do you guys think? Anyone up for making them and if they work marketing them for all the 3rd gen ARB/ and other bumper guys needing fog lights?
dont have an answer....but looks good, really helps me figure mine out as my 4runner same color.
see that you mounted winch controls up top..I was planning to put a light bar there
will be interesting to see the solution for fogs, as I want to have fogs and light bar ( up here called moose lights)
looks like your spring/shock combo is handling weight just fine...how does it ride ?
thanks. As to your light bar you can alway hang it upside down on the top bar or put spacers above the winch for it. I'm going to add two spots on it eventually.
I did up grade my coils to the OME 2882 to handle the weight. It's a bit higher right now than I usually went (2") it's over 3" right now to handle the sag since the coils are brand new. So far so good. I can definitely feel the extra weight in the front and I'm sure I'll get use to it soon enough. I'm not high up enough for Moose, but we do have Elk around here among other things.
