Audi Allroad
flying fuzz
Member
Anyone here have any experience with the Audi Allroad? Looking at either 2003 2.7T or an 2005 with the 4.2L, both have about 107,000 miles. Curious as to reliability or known issues that pop up, It would be used as a secondary vehicle but I am not to familiar with Audi's like I am Toyota. I know they can be expensive for parts replacement but at what mileage does the age start showing?
Thanks for any input,
Tom
A couple of my friends are diehard Audi guys, but they never keep them past 60k miles or so. One of them did. It was a 2003 AllRoad. He kept it because he loved it so much. Until the tranny went at around 95k and it cost almost $7k to replace it.
Good advice, thanks guys. Not sure why I have this hard-on for the allroad, just seemed like a slick, functional and fun car.
Stay Safe,
Tom
Stay Safe,
Tom
It's because they are. Wagons are SO functional. Especially if you live in or around a city. And the AllRoads are a ton of fun to drive. They're just not built for longevity.
We had one, I wanna say it was an 04. It was an awesome vehicle but maintenance was crazy, I wanna say changing the spark plugs required pulling the turbos, and it needed new rotos at each brake job? If you're serious I'd ask audi for costs of common maintenance items.
The old Allroads are strange, they need work, lots and lots of work, but for whatever reason in Colorado they are like gold. The resale price on a V6 turbo with a manual trans is ridiculous. The people that have them love them and will not get rid of them.
Common problems - cracked rubber brake lines, all of the front suspension bushings, front sway bar bushings and end links, leaking malfunctioning air suspension problems (I've installed more of the Arnott air suspension delete/coil spring kits than I can remember), engine mounts, cam adjuster seals, cam plugs on the heads leaking, the rubber Y piece where the 2 charge pipes join together cracks, vacuum line sand breather pipes cracking, heater core clogging up, leaking water pump, yellowed headlights, turbo oil return lines, cats, CV boots, ball joints.
For what it's worth it was common thing to have a customer buy $5,000-$7,000 worth of work on them to get them freshened up and ready to go. That being said, it's not continuously the same parts failing over and over, it's more age and lack of proper maintenance that have built up to crazy repair bills one time.
That is not even close to true, spark plugs are no big deal at all.
Perhaps, I wasn't the one taking it in for service. But I distinctly recall some sort of absurdity. Something involved pulling the turbos, I'll have to ask. I still recommend anyone looking into audi's, or any higher mileage used vehicle for that matter, to check-in on what common service costs are. Thanks for checking me on that, not trying to dispel falsehoods.
Personally (I will get flack for this but idc) I wouldn't buy any German vehicle used over 10 years old or over 100k and here's why:
The engines are usually fine but it's everything else that tends to flake out rather at once or at decently rapid rates
Most people (not all but the vast majority) that buy them can afford the payments but they don't bother with the upkeep too often. Sure, most vehicle owners don't bother with too much upkeep but it's cheaper to fix anything not German for the same parts. Plus a lot of shops won't work on them or if they do it's stupid pricey and you need special tools to do half of the normal things
Realistically, if you keep up the maintenance items and put the grand in to them each year they require you won't have many issues but most people don't check things and once it goes bad they sell it because it's a $4k fix right now.
Good insight guys, thanks. [MENTION=113771]AudiTech[/MENTION] that's the information I was looking for! I'm familiar with Germans as I had a VW MKIV GTI many many years ago so I'm not too scared and as most have stated it's the general up keep that most slack on. I've found a couple sub 100K mile vehicles, trying to stay away from the 2.7T and would rather have the 4.2 since that's a pretty solid engine. Although there are a lot of goodies for the 2.7T...
Stay safe,
Tom
emilygrace28
