"Auto Tech" Timing belt. Troubleshoot HELP
LCPLHumiston
Notice: Whats underlined and in Bold is the actual issue im having but everything before that is an introduction of what was going on
So how do i start this off. First off if you live in St. Marys county Maryland do not go to this guy. I heard great things about this guy like "He is the only mechanic i trust" "I do everything with him" "i get all my parts from him" So i was like ok this guy is legit. So i went there he is a menonite "men in knight" he works out of his garage with his son. Well i took it there came back the next day. I had my Timing belt, water pump, idler pullys and a O2 Sensor replaced. Granted his son did all the work on my truck. So i drove my truck out of his drive way heard a rubbing noise had my dad drive it. he immeditaly stopped and was like its really loud. so we went to the front right tire where the noise was. The lug nuts were not even HAND TIGHTEND! they werent even snug...one lug nut fell off while i was leaving. we went back they hand tightend left..came back still made the noise. The Rear brake with the sheet metal was bent and rubbing on the drum itself. So they re-bent it. Fixed. Ok so 2 days later my truck when it first starts up will idle fine and it rolls fine once you get off the break. BUT as soon as you get on the accelerator it wont get past 2,000 RPM and if i give it gas the engine will make popping noises and still gets up to about 20 MPH. So i have to find somewhere to pull over turn it off and turn it back on and just floor it to get it past 2,000 and it struggles to do that. Any ideas of whats wrong i have been told the timing was off. Im not sure.
Nope no check engine light and yea it ran fine it was a little different driving. The Steering felt a little more precise but now if im at a dead stop and you turn it all the way(yes i know it makes a noise) but now its REALLY loud.
It sounds like it's just a misfire, I don't think the timing belt jumped after being ok for 2 days. If it is a timing issue I would take it back to Shadetree Automotive to have them fix it. You should line the timing marks up on the crank and pull the timing cover and see if the cams are on their mark.
It could've dropped a coil pack or injector but hopefully its something they did so you don't have to worry about it.
Thats what im saying haha. Not gonna lie when i went through the flooded waters with my friends may have fcked it up. Since the check engline came on. but it ran fine with that light on went away after 2 days. my friend ran a smart computer and said it was an 02 sensor so the guy replaced that with my timing belt and stufff
Problem Fixed: They got the wrong part from their parts dealer and got an 02 sensor without a sensor haha. So they put a new one in and it runs perfectly fine. Although they did want to charge us for it, my dad was like fck no you did all this wrong on top of putting on a wrong sensor.
OK. Care to explain that one?? Thanks...
Ok i asked. he got an oxygen exhaust sensor and not a fuel sensor...or something along those lines.
OK, trying to translate, sounds to me like you have a Cali. emissions rig (like me) that uses a wideband air/fuel ratio sensor instead of the standard oxygen sensor. Sounds like he installed an O2 in the front on a Cali. rig. instead of an A/F. Does that sound right?
That sounds exactly right, a couple of my friends said hopefully its not a cali one haha. Yea man thanks for translating that to me also!
