Auto window up feature
5VZ-FE
Member
Today I converted my manual (crank) windows to power windows in my '99. When I use the 'auto down' feature the window goes all the way down. When I use 'auto up' the window goes all the way up, and then back down to halfway open. Has anyone ever had a problem like this? Any ideas for a fix?
Pretty sure you motor or gear isn’t clocked properly.
Got to be a thread on here for it. But what term to search???
That up, then half down is the auto window safety feature. It will do that if you put your hand in the window and stop iit. It’s hitting resistance before it thinks it’s all the way up.
Most toyotas need to learn max "up" position. Run window up all the way and continue to hold up for 3-5 seconds then release and recheck.
