Auto Windows Button
H1_VLTG
The driver's window is the only one that has the auto up/down feature. I want to change the buttons so all 4 windows have this feature. Anyone done this? If so, how much did you end up spending, time and money?
Well I haven't done it myself, but you need to replace the modulators too because they tell the switch when the window is up or down. I Don't think it would be worth the money, but that is just my opinion.
Thanks, That was the type of answer I was looking for. I didn't know what would be involved.
If I can some how get hold of the modulators for a cheap price I might look into it.
The OEM motor may be different for the auto up window regulator. Usually this motor contains a Hall effect sensor to provide positional information to the ECU (controller). If the motor connector contains more than two pins then this is the case.
Thanks for the info, I am looking to do this upgrade this summer, along with getting a sunroof put in.
My thoughts are to then have a one button operation that will open the sunroof and all 4 windows at the same time. Might be more trouble than it is worth, and if that is the case, I'll focus my efforts on my project/play car (a 1991 camaro)
EnviroHokie
