Auxiliary backup lights
Myrunr2010
So I'm in the process of working on a rear bumper build (it's not far enough along to post any pictures). As part of this I would like to wire in some auxiliary backup lights. Ideally I would like to wire them up to come on when the vehicle is in reverse, which shouldn't be super difficult. The part that I'm unsure about is that I would also like to wire a switch to the dash to be able to turn the lights on on command, so if I'm doing something behind the vehicle I could have some light.
Has anyone ever done this? What challenges do you see that I would have to overcome? Just looking for some knowledge/input.
I did in 2011, one of my more useful mods. It's in my build thread if you want to see if what I did works for you. I have the switch so they can be turned off, turn on with the reverse lights and turn on without the reverse lights.
Post 278 is prolly what you'd be most interested in...
http://www.yotatech.com/f200/habaneros-1996-4runner-build-up-thread-201751/index14.html
I seemed to initially have some problem with my fan switch as it was not true on-of-on but it's been working fine since. Not sure why the problem but it is off-on-more on- low and high are not entirely separated. You may want to try a different switch though the Toyota fan switch did end up working out for me.
It was not hard to do, just running wire, a relay, a tap, a switch...
seltzernator
