Availability of rear lockers on 4th gens and A-TRAC
dontdo_that
I had a few quick questions about A-TRAC II+ and Rear lockers on 4th gens. I owned a 3rd gen for 10 years and was looking at 5th gens but decided against buying new. Now considering 2007+ 4th gens and am slightly confused about the availability of these options.
These questions were formulated after reading the literature on Toyota120 and the pre-purchase resources stickied here:
http://www.toyota-4runner.org/4th-g...modifications-write-ups-quick-links-faqs.html
Is A-TRAC II+ available in ALL 4th gen 4runners? The verbiage makes it sound like all 4th gens, regardless of trim, have A-TRAC.
Can A-TRAC be switched off in the 4th gens? No explicit mention of this although some cursory searching of forums (this and others) suggests that it cannot be in the 4th gen 4Runner (but can be in the Tacoma).
Which trim packages, other than the 2009 Trail Edition have the Locking Rear Diff option, if any?
Any of you who have shopped for a 5th gen know the difference between ATRAC in 4th gens compared to 5th gens? Do the 5th gens use A-TRAC II+ too?
Thanks a lot, I know these questions have been asked before but there is so much info out there it's hard to find your exact query.
As far as I know, ATRAC is standard across all years & trims of 4th gen T4Rs. *I'm not sure for 2wd versions though, but I think it's still there.*
The only year / trim that had an ATRAC disable switch was the 2009 Trail Edition. Prior to that, all trims received a VSC disable switch in 2008. There's a (somewhat) easy mod you can perform to disable ATRAC/VSC/ABS for any year / trim though, see here.
The only year / trim that had a locking rear diff was again, the 2009 Trail Edition.
Unfortunately, I can't comment on the 5th gen's ATRAC system.
Hope that helps!
Hope that helps!
Was the rear locker in addition to the center diff lock?
If you have a VSC off switch you can turn off all traction control including ATRAC by holding the switch down for 10 seconds. I have it in my 08 and didn't realize that's what happened, thought my ATRAC was broken lol
cremebrulady
