V8Limited4wd
So I recently had my timing belt and water pump replaced, along with the radiator, a/c condenser, thermostat and all the hoses - basically the entire front end of the engine. I had it done by my brother who is a mechanic who did it for free - just gave him money for the parts. After driving Bessie back to VA from Philly, I checked the coolant tank and noticed it was low, so I filled it back up. I also noticed that the top radiator hose had moved a little on both ends. For the next three weeks I drove it around while constantly checking the coolant tank and refilling it, as well as adjusting the hose. So I was able to determine the leak was coming from the Koyo radiator - so I figured, oh it's a bad radiator so that will be easy to replace.
The other day I was sitting in traffic after picking up my daughter from daycare, and I hear this loud POP from the engine bay and see steam coming out. Thankfully I was near a huge exit ramp and pulled over to the shoulder. I open the hood and saw that the top hose detached from the radiator and sprayed coolant everywhere. Luckily I had my leatherman tool and extra coolant, and even more lucky that the engine didn't overheat.
Turns out the thermostat was stuck closed, causing excessive pressure in the system. This caused the radiator to start leaking, and also a tiny leak in the area under the intake manifold where the thermostat is. I'll be driving up to Philly to get the radiator and thermostat replaced, but was told to have the thermostat completely removed before driving up. I didn't think the thermostat was an issue since the engine temp always stayed in the middle the entire time I was driving. Apparently it is still able to release the heat through the heater core. And since most of my driving was on the highway, it kept the coolant temp/pressure low enough.
Anyways, just wanted to share just in case anyone else is having similar issues after replacing their radiator/thermostat. I really dodged a bullet there.
